Hi. I m currently working for a constructions company as a land surveyor and I have to create an online map with polygons or points that represent the places of company's projects (past, present or future projects), giving some basic information. The map will be shared to everyone (public) through our web site. There s no need to be accurate (coordinates etc). Which type of arcigis pro license is suitable for this kind of project? Do you think that basic licensing with creator user type is enough? Thank you
Yes if you aren't going to do any analysis or higher end database construction/maintenance
If you want to explore tools that you might use in Arctoolbox, every toolset or extension has a licensing matrix.
For example Analysis toolbox licensing—ArcGIS Pro | Documentation
If there was a tool/functionality that you need that requires a higher license level, then factor it in.
But basic make a nice map using ArcGIS Pro and ArcGIS Online should get you going.
I would check its help files as well.
Get started with ArcGIS Online—ArcGIS Online Help | Documentation
Well actually I m thinking of a web app with some basic tools (measure, filter, printing, etc). No analysis at all. Really thank you for your help.
Basic and AGOL would probably be fine.
