Labels add decimal places to number - ArcGIS Pro
1247
05-31-2024 03:37 PM
AmyNewsam
Hi All,
I created a shapefile and added a number field with the specifications float, precision = 4, scale = 2.  When I label the features using the number field, I get 15 random extra digits to the right of the decimal place.  I'm using Pro 3.2.2.  Any help appreciated.
Amy
RhettZufelt
MVP Notable Contributor
You can use the round function to control the decimal points on labels as shown here.
Don't see it in the docs, but 'floor' works as well as round depending on which direction you want to go.
R_
RhettZufelt
R_
AmyNewsam
Thanks Rhett, that worked great!  It does seem odd though, since the number is set to a scale of 2, and I entered the number manually as "1.6", why would it add all those extra digits?  just curious.  😉
RhettZufelt
Couldn't tell you why, but can confirm it.  If I create a field as 'Double', it behaves as expected.
Thought maybe you are using a File Geodatabase (or mobile) and according to this, precision/scale is not supported.
However, testing in SDE environment produces the same result.........
Also, noticed the number format in the fields view doesn't alter this anymore either.
R_
AmyNewsam
Thanks, Rhett.  I'm not using a file geodatabase or mobile, so I guess it will remain a mystery.  🙂
