jpg failing to add to arcgis pro
448
08-09-2022 10:17 AM
JGVadnais1
I'm attempting to georeference a jpeg.  When I click on Portal, inside the Catalog Pane, the image is there but cannot be added.  Be help.
DanPatterson
MVP Esteemed Contributor
related?
Solved: Adding jpg to ArcGIS Pro Map: "Failed to add data,... - Esri Community
Do you get an error message?
Does it appear in the table of contents, but you can't see it?
Can you drag the image onto an empty map?
A screen grab of what you are doing won't help
... sort of retired...
