Is there any way to export a symbol icon from ArcGIS Pro?
2447
7
06-12-2018 09:03 AM
MichelleTanner
New Contributor III
I have made a symbol in ArcGIS Pro, and would like to export it as a .PNG, .SVG or similar to use in other programs. Is this possible at all? I've only been able to export it as an Esri style file.
Thanks!
SaraMoulton1
New Contributor II
I also have this question.  Did you get an answer elsewhere?
MichelleTanner
New Contributor III
No
AdamBourque
New Contributor III
Any luck?
AdamBourque
New Contributor III
Any luck?
SaraMoulton1
New Contributor II
I haven't followed up on this since last summer, but below is a work-around a colleague suggested back in July 2019.  It is less elegant than a direct export, but I was able to get the end result I needed with it.
"There’s no direct export symbol as sort of thing.  I would create a small layout and have one feature and no basemap and export the layout as a PNG with transparent background."
ArielLow2146
Occasional Contributor II
I'm also curious whether there is a way to do this. Has anyone gotten an answer?
jiaqili1
New Contributor II
Is there any answer?
I want to export the ENC chart's symbology.
