Is there a way to create a polygon from a map frame extent in ArcGIS Pro?
4765
6
01-07-2021 04:11 PM
SterlingL
Tags (3)
2 Solutions
MarkBryant
You can do it via code.
import arcpy
#Reference the Project document from within PRO
aprx = arcpy.mp.ArcGISProject("CURRENT")
#Reference the layout
lyt = aprx.listLayouts("your_layout_name_here")[0]
#Get the Map Frame
mf = lyt.listElements("mapframe_element", "your_mapframe_name")[0]
extent = mf.camera.getExtent()
polygon = extent.polygon
You then have a polygon object that you can work with.
Note that this code just grabs the extent, if the map frame is rotated, the extent doesn't match what you see on screen.
Mark.
DanPatterson
MarkBryant
import arcpy
#Get the Map Frame
Mark.
SterlingL
Thank you sir! This worked marvelously.
Katerina1
Hi Mark,
Can you please indicate how to save the extent as a feature class? I tried InsertCursor but it didn't accept the polygon object, it requires list of floats instead.
Many thanks,
Katerina.
DanPatterson
Using tools in ArcToolbox
Create Fishnet (Data Management)—ArcGIS Pro | Documentation
... sort of retired...
SterlingL
Dan this works great as well! Thank you.
VeraNeroni1
This worked great! Thank you!
