Is there a way in Pro to apply a Color Scheme to a selection of values?
1129
08-14-2018 03:19 PM
StevenDague
New Contributor III
 Example, I have 20 different unique values to symbolize and I would like to have groups of 2-6 be color ramps of different base colors, like a blue, red and green continuous scheme across 3 selections of values.  I can do them manually, but applying a ramp based on a selection of the values would speed up the initial symbology.  Thanks.
Steven Dague
GIS Analyst
DanPatterson_Retired
check some of these in your symbology... don't get excited, this just describes them
Color schemes—ArcGIS Pro | ArcGIS Desktop
in the color schemes (the old color ramp)
AndersOlsson
New Contributor II
Have you find any solution to your problem? I am also trying to do this.
I think it's possible in ArcGIS Desktop
JeremyFreund1
New Contributor II
You can achieve this by using multi-part color schemes. The only hitch is that the breaks in the parts are described as percentage of the total color scheme and not based on pixel value, so you will need to scale in the case where your pixel values are not 0 -100.
