Is there a keyboard shortcut for the Apply button in the Attribute Editor Pane?
917
07-26-2023 06:55 AM
NickN
Sometimes, when I'm doing attribute edits I turn off Auto Apply so I don't get thwarted by the applying edits dialog. I know you can eventually tab down to the Apply button and tap spacebar, but is there a shortcut like F2 for drawing?
jcarlson
MVP Alum
I'm not at a computer w/ Pro to double check this, but I thought it was Ctrl + Enter?
- Josh Carlson
Kendall County GIS
NickN
Yeah I tried that, no dice. I didn't see anything in the shortcut documentation either, and I don't see how you can assign it as an accelerator as you can with other toolbar buttons. Bummer 😞
NickN
I guess I have a workaround. In Options -> Editing you can set "Uncommitted attribute edits" to Apply (defaults to Always prompt I think) then when you click off the features you're editing they apply automatically. Not optimal, but since I'm usually moving on to the next batch of features it works for that workflow.
