Is the “find and replace” tool available in the latest version of ArcGIS Pro,
4353
36
11-17-2017 12:24 PM
JamalNUMAN
Legendary Contributor
Despite the fact that there is a workaround for this, however, this tool is heavily needed as it is considered the main SEARCH tool. What is the point if searching the data is not straightforward?
FAQ: Is the Find and Replace tool available in ArcGIS Pro?
https://support.esri.com/en/technical-article/000014591
Jamal Numan
JamalNUMAN
Many thanks Alycia
Best
Jamal
Jamal Numan
AlyciaRajendran_esri
Jamal NUMAN‌, this has been fixed in the 2.5.1 patch. For information, please see: https://community.esri.com/docs/DOC-14931-arcgis-pro-25-patch-1-is-available
JamalNUMAN
Many thanks Alycia for the update
Best
Jamal
Jamal Numan
ChristianVogt-Heinze
I am working with Pro 2.5.0 and it seems, that vowel mutations ("Umlaute", ä, ö, ü) are not supported.
Thank you for reporting this, Christian. I am able to reproduce this. I have created a support issue number so you can track the development status: BUG-000129282.
Thanks again,
- Alycia
Christian Vogt-Heinze‌, this has been fixed in the 2.5.1 patch. For information, please see: https://community.esri.com/docs/DOC-14931-arcgis-pro-25-patch-1-is-available
JamalNUMAN
Is the issue of not having the “find and replace” command for standalone tables fixed starting from version 2.7?
Jamal Numan
