Is it possible to set the extent of a feature class programmatically using ArcPy
1056
09-26-2024 11:50 AM
ChenChen4
I have 500+ feature classes stored in an Enterprise Geodatabase. The goal is to update extent to each feature class to match the Organization's extent. Does ArcPy have the function to perform this task?
DuncanHornby
MVP Notable Contributor
Yes it would be very easy, you use the Describe object on a dataset.
ChenChen4
Thanks my friend. I know how to GET the extent of a feature class:
desc = arcpy.Describe(fc)
xmin = desc.extent.XMin
xmax = desc.extent.XMax
ymin = desc.extent.YMin
ymax = desc.extent.YMax
But what I need is to RESET the extent. I know I can change the output extent in the environment settings using the Extent class, but this only defines what features will be processed by a tool. It does not alter the actual geometry of the feature class:
arcpy.env.extent = arcpy.Extent(-107.0, 38.0, -104.0, 40.0)
Thanks
MarcoBoeringa
Well, there is the:
Recalculate Feature Class Extent (Data Management)
geoprocessing tool that you could easily call from ArcPy. Do note though that it requires an exclusive schema lock, which might be problematic in some cases.
It also calculates the extent based on the actual features according to the Help page, while your first post suggests setting a predefined "organization" extent that may not reflect the actual data's true extent.
I am not sure if that is possible with the ESRI tools, or if you would need to hack into the geodatabases system tables to achieve that.
ChenChen4
Thanks.
There is no input parameters to set xmin, ymin, xmax, and ymx in the RecalculateFeatureClassExtent function. It simply updates the x,y,z and m extent properties of a feature class based on that's already set in that feature class. It won't allow me to set the custom xmin, ymin, xmax, and ymax values.
I'm exploring the update cursor option and trying to figure out if I can do so by altering a feature class @SHAPE attribute.
BobBooth1
You could Clip the feature classes to your organization's preferred area. This would remove data outside that area.
