Is georeferencing impossible in Pro, or what?
3099
11
09-25-2023 03:33 PM
AvaFarouche
Greetings!
I'm in Pro 3.1.3.  Every time I try to georeference in Pro, I find it impossible. I used to georeference a LOT in Map and it's a big part of my work.
In Map, I used to be able to open a separate window to see the imported image layer in that viewer, and add control points before Adjusting to Display.  Now that extra window feature is gone, which means I can never really see the points I need to line up - first of all. Is there any way to get that separate viewer window for the imported image that used to exist in Map????
Someone recommended to turn off Auto Apply - which seems like it should help, but in the end, it doesn't.  If I turn off Auto Apply, I zoom back and forth between the layers, and I can add a number of well-distributed control points - but then when I try either the Transformation or Apply, everything just disappears.
If I had the viewer window so I could see both layers at the same time, I think it would help, because I could add more control points. I work with a lot of imported imagery layers that I need to fit to other imagery layers with control points. If I were working with clear linear graphics, it would be easier, but I often don't. I need to be able to see both layers, clearly, separately, at the same time. Zooming back and forth doesn't work when I'm trying to match up topo contours and hillshade contours for control points, and neither does transparency.
I am kind of freaking out here, because it seems like all of a sudden a very important part of my job is impossible with Pro. It seems like the only solution is to Georeference in Map, create my shapes in Map around the referenced images, and then import the shapes I've created into Pro. That's what I've been doing so far. But there are obvious problems with this as a solution, never mind that Map is going to be phased out.
I'd love to hear from others: What has your experience been? How often do you georeference in Pro? Do you have problems? What do you do about it? Is there ANY way to get that separate viewer to add control points before Fitting to Display, like there was in Map??????? That would be a lifesaver.
Thanks!!!!!
AvaFarouche
Oh no!! What a bummer to hear that it's buggier! I have to give up my ArcMap license in April and I'm super sad about it. The only thing I use it for anymore is georeferencing, but that's a really important part of my job sometimes and so far Pro just does not measure up to Map in that functionality, at all.
SparwoodUser
Pro broke the georeferencing workflow it seems.
It should be a no-brainer - two windows that pan together, one with the image being georeferenced, the other with the control point or reference layer. Be able to create control points by clicking in one window first then the other, and possibly have the image window rezoom or pan to keep the image framing consistent.  No turning layers on and off all the time nor having to zoom and pan manually.
