Is ArcGIS Pipeline Referencing functions are included in ArcGIS Pro 2.6 and later versions?
822
12-27-2020 12:34 AM
Labels (2)
ThamerTarabzouni
New Contributor III
1- Is ArcGIS Pro 2.6 and later requires the purchase of ArcGIS Pipeline Referencing software extension to have access to these functions and implement LRS networks, or the native ArcGIS Pro 2.6 is equipped will the functionalities, so there is no need to buy the APR software extension?
2- To enable users of an enterprise application to display and work with APR LRS after publishing them using ArcGIS Pro desktop, do I have to install the ArcGIS Linear Referencing for Server?
DanPatterson
MVP Esteemed Contributor
You can check requirements for tools in the help.  For instance
Get started with Pipeline Referencing—ArcGIS Pro | Documentation
Available with Location Referencing license.
Near the title of that link, you can toggle between version 2.6 and 2.7 of arcgis pro
Server's help is in a separate help system
Enabling the linear referencing capability—ArcGIS Pipeline Referencing Server | Documentation for Ar...
... sort of retired...
ThamerTarabzouni
New Contributor III
Hi Pan,
Thank you for the feedback and sharing these links.  I went through them quickly, and also other links referring to ArcGIS  Pro Pipeline Referencing but my questions were about  do I have to purchase the APR extension for the ArcGIS Pro so I can be able to use the LRS Geoprocessing tools or they came impeded as standard tools in  ArcGIS Pro 2.6 & 2.7.   Similarly,  is server extension is needed or it comes bundled with the Enterprise ArcGIS server?
DanPatterson
Just check for the locks in ArcToolbox to see .  In my case I don't have any "referencing" extensions, so a lot of functionality is impeded.
