Inverting the order of raster values in the legend
2911
10-11-2022 08:56 AM
katemcc918
By default, ArcGIS Pro displays stretched raster symbology values from greatest on top to least on the bottom. I would like to show this raster in my map legend with the smallest value (16.3) on top and the largest value (95.6) on the bottom. I see that you can invert the color ramp, but that does not affect the order of the actual raster values. Is there a way to invert these values for the purposes of the legend?
DuncanHornby
MVP Notable Contributor
This is possible certainly in ArcPro 3.1.0.
Here is an example for a default setting for a raster added to the map:
Clicking the invert option simply inverts the symbol as shown below, but not the labels:
You need to set the stretch type to min/max, note new tick box options appears in symbology pane.
Tick on edit min/max values, swap the values around and hey presto you get your low - high labelling as desired
Although I show you a solution I think in the case of this elevation dataset it does not make sense, so be careful when inverting values/labels to make sure what you are showing is understandable to the map reader.
MichaelCairns1
Did you ever get an answer to this problem? It would seem so simple but I cannot see how it can be achieved - common for geological data - Shallow to Deep for example.
DuncanHornby
MichaelCairns1
Thank you for taking the time to step through this. Will need to upgrade to ArcGIS Pro 3.1.0
