integer values of 50, 100, and 300 to your attribute table. Your projected coordinate system is NAD 1983 HARN California (Teale) Albers. What units are your buffer distances going to be in when they are created with the buffer tool?
683
03-20-2018 08:00 PM
KatelynnWalton
buffers
RobertBorchert
Honored Contributor
Go to the table of contents in an the MXD your going to use the tool in.
By default the top of the table of contents is called Layers
Right click on Layers and select Properties.
Click on the General Tab.  In the middle it will show Units. There will be Map and Display units.  Map is what the buffer will be made in.
KatelynnWalton
you're my hero! thank you so much!
