In ArcMap I can select the "Go To XY" tool, input my X and Y values, and then select the "Add Point" button and a marker is created at that location. Does ArcGis Pro have this fuctionality.
3628
12
01-01-2020 10:26 PM
BENNYROBERTS
Adding a "Marker" in Pro.
Scott_Harris
Hi Benny,
Here is an editing-centric method for creating a point feature at a specific XYZ location:
1. Add a point feature class to the map if you don't have one already. You can use Map Notes if you want :
2. From the Edit tab > click Create:
3. From the Create Features pane, choose the point template:
4. Right click on the map and choose Absolute X,Y,Z (or use the F6 keyboard shortcut):
5. Choose the desired location units, type in your values and hit ENTER:
6. The point will be created at that location and will be selected. You can zoom to the location if needed by using this button on the bottom right corner of the map:
Relevant link for this:
Specify an x,y,z location—ArcGIS Pro | ArcGIS Desktop
Scott
BENNYROBERTS
Thanks very much Scott, this procedure does exactly what I need.
ThomasColson
I believe the OP is referring to the capability discussed in https://community.esri.com/ideas/13658 .
