In Arc Pro is there a way to load multiple photos to a single point?
2474
03-01-2017 08:53 AM
kristinaperreault
In Arc Pro is there a way to load multiple photos to a single point? And then later to be able to add additional photos, pdf and text. I'm basically trying to create single point features that can be updated with images and new information as the project grows. I'd then like to share this to ArcOnline. Is this possible?
JakeSkinner
Esri Esteemed Contributor
Hi Kristina,
Take a look at the following help document:
Work with file attachments—ArcGIS Pro | ArcGIS Desktop
kristinaperreault
Thank you this was one way to add multiple photos at once and a pdf!! Is there a way to configure the pop up so that it can display the attachments when you click on the point?
kristinaperreault
I found that once you hit save the items populate in the pop up. Now I'm trying to figure out how to publish these to ArcOnline, I keep getting "Staging Fail" and have tried lots of suggested solutions. And in ArcEarth the attachments show a link, but then when clicked on say that path cannot be determined. So I'm stuck because I can load and edit in Pro, but now I have no way to share with my agency. Any ideas are welcome.
