Importing Custom Point Symbols
6495
7
05-25-2018 09:26 PM
MichaelLohr
Occasional Contributor II
How do I import 3rd party Point symbols (png format) in ArcGIS Pro, so that they are available in the Symbology Gallery?
I tried looking in the Help but no help. Maybe I missed it.
DanPatterson_Retired
Untried but highly recommended... picture marker in Xander's post https://community.esri.com/message/622073?commentID=622073#comment-557184
MichaelLohr
Dan, this is somewhat helpful, in that it allows you to attach to an outside picture file for a particular symbol. Tried it, it does work. But it does not add it to the Symbol Gallery where it would be available for other maps. Also, it appears to be a one-at-a-time as opposed to importing a group of new symbols.
You are able to do this in ArcMap Desktop
Thanks Dan.
KoryKramer
Esri Community Moderator
What about adding a point symbol to your Favorites.stylx
as a PNG?
Then its available in all projects from the gallery:
How were you bulk importing in ArcMap?
MichaelLohr
Thanks Kory. Another good thought. Much appreciated.
But it still is a one at a a time process. I know that there are Symbol Libraries for about any industry you can imagine, with hundreds of symbols.
In ArcMap, you would run the Style Manager, then add a new style, browse to where you had downloaded a symbol library in a .style format, then upload that entire library at once, markers, line symbols, fill, etc. Whatever is defined in your .style file. Only works, obviously, if you have a correctly formatted .style format, not a folder of BMP symbol files.
I am new to ArcGIS Pro and did not see a similar Style Manager interface, which prompted the original question.
Is the .stylx the ArcGIS Pro equivalent to the ArcMap .style file?
GitHub had a possible item to try, but I have not explored it
GitHub - Esri/solutions-symbology-data: Source data for Solutions Symbology used in Templates (Note:...
KoryKramer
Yes, the .stylx is the Pro equivalent to the ArcMap .style file.  If you already have the .stylx, just import it to your Pro project.  Add styles to a project—ArcGIS Pro | ArcGIS Desktop
You can either add symbols to your Favorites, or you can create a project template containing a connection to your custom style and whenever you want a Pro project with that style, create it from the template.
Create a project template—ArcGIS Pro | ArcGIS Desktop
ZacharyKlaas
New Contributor II
I have no trouble adding the point symbols to my gallery, but arcpy scripts can't see what I've done.  Manually I can click on my added point symbol from a new mapicons.stylx file, but arcpy can only see my system styles, not any I've added to the gallery.  Is there a reason for this?
AnaVillaran
Hi Zachary, were you able to relate the stylx file within the script?
I am trying to access custom symbols stored within a shared drive so that multiple users are able to use a script tool; however, the script doesn't seem to be able to identify that style file when I try to use 'item.symbol.applySymbolFromGallery'.
