Identifying the steepest segment of a line in ARC GIS Pro
4448
14
02-01-2021 09:18 AM
AndrewMulford
Hi, I am attempting to identify the steepest portions of a line in arcgis pro. I have a line feature with z values and a DEM. I have calculated maximum slope for the entire line using the "Add Surface Information Tool". Now I would like to identify the location of this maximum slope along the line. Is there a tool for this in ARC GIS Pro?
-Andrew
DanPatterson
MVP Esteemed Contributor
I would need examples from your tables to see what is going on.
Use Add Geometry attributes to get the x, y coordinates of the start end points and their Z values.
Also... You are using projected data (?)
... sort of retired...
AndrewMulford
Ok, The data is in a GCS. I ran split line at vertices and then ran the add Geometry tool. Then I added a field "avg_slope" and used the python script you gave me in the field calculator. Still getting very large values. I am attaching a screenshot. The average slope of the entire line is 8% and I am trying to identify segments that are above 15 %. I am attaching a screenshot of the table. Cant thank you enough for your patience and help!
DanPatterson
Your slopes will make no sense if your x and y are not in planar units (aka meters) since your elevations are in planar units (meters).
Slope has to be calculated using projected coordinates.  Either use a projected file (like a UTM or even an Albers or something local) or use the Add Geometry Attributes to get the coordinates in projected units before calculating slope
AndrewMulford
That did the trick! You are a hero. Thanks for the kind and patient help.
DanPatterson
Glad it worked out!
