Identify Points Within Radius of Coastline
1549
09-01-2021 01:00 PM
Labels (2)
CraigHarris1
Hello:
In light of hurricane Ida, is there a way in Pro how I can calculate / determine which of our locations are within a 50.0-mile radius of the U.S. coastline please?
Any suggestions would greatly be appreciated - thanks!
Craig Harris
2 Solutions
David_Brooks
MVP Regular Contributor
Here's a simple solution for you:
You need a dataset for the US coastline (see below). and then use the select by location tools
This feature service for the us coastline could be used:
https://services7.arcgis.com/jF2q3LPxL7PETdYk/arcgis/rest/services/US_Coastline/FeatureServer
David
..Maps with no limits..
DanLee
by Esri Regular Contributor
You can run Near tool with the coastline as the Near Features and 50.0-mile as search radius.
You can also use Select Layer By Location using "Within a distance" option and the same search radius.
David_Brooks
David
CraigHarris1
Thanks David!
DanLee
CraigHarris1
Thanks Dan!
