I am not ArcPy developer, so may I have a dumb question, but I will try. In ArcMap, I want to add a specific value in the column for point, which is in the selected layer. For example, someone will select the layer and I want to run for loop and change values in db for the points which is in that layer. Is it possible? What can I do?
I might be missing the details of what you want to do, but it sounds like after selecting a layer you could either call the Calculate Field tool or run through rows with an Update Cursor.
And you have posted your question in the ArcGIS Pro forum. You might delete the post and re-post your question in ArcMap Questions - Esri Community
