I want to create outmost outline of this kindlike polygon not include inside island's outline. How can i reach this goal.
1910
7
10-07-2023 06:40 PM
YLZ
DanPatterson
MVP Esteemed Contributor
why not use ArcToolbox tools...
Eliminate Polygon Part (Data Management)—ArcGIS Pro | Documentation
will do the job without having to edit each one
... sort of retired...
HarishKV
It's an easy job. Create the outer polygon and the make it transparent going to the symbol ogo tab. Create the inner polygon where you want the lake like feature. Select the inner polygon and use clip geoprocessing tool. There will be option to remove the touching polygon area. Or else delete both the inner polygon and the clip created.
YLZ
Maybe there's a problem with my expression,there is only one feature in my picture. So once i choose, i choose it all, i can't choose the outer polygon.So called inner polygon is empty, i can't choose it.
HarishKV
Can please tell me the version of arcgis pro you are using
YLZ
DanPatterson
HarishKV
Use the tool in the Screenshot. Setting also to be followed
YLZ
Thank you sir, i cant choose the inner polygon, so i cant use the clip tool.I've used eliminate polygon tool. Still thank you for your help.
