I need to download and authorize ArcGIS Pro on a new computer.
1532
8
08-27-2020 01:57 PM
LonOttosen
How do I go about installing Pro on a new computer and moving my license to that machine.
thanks
DanPatterson
DanPatterson
depends on your license type (single, named user, concurrent)
ArcGIS Desktop license types—ArcGIS Pro | Documentation
and
Download, install, and authorize—ArcGIS Pro | Documentation
... sort of retired...
LonOttosen
Sorry, I have a named user license.
DanPatterson
The second link then.  Since you are a named user, then you can download and install it on your new machine from My Esri through your organization.
As a tip... save the *.exe file to disk, run it and it will extract a *.cab and *.msi file... run the *.msi file to do the install.  If you have to move or reinstall, you don't need to go through the download process
LonOttosen
Thank you. I appreciate the help. Have a great day.
MaggieArdito
I also need to install Pro on a new machine... do I install a trial version and then move the license or what?  Thanks for help.
by Anonymous User
Not applicable
The downloads for ArcGIS Pro can be found on your MyEsri site through your organization. No need to install a trial if you have the download link available on MyEsri.
Hope this helps.
Gillian
LonOttosen
Thanks..got it going. It certainly wasn't as hard as I anticipated.
MaggieArdito
Once I got past the problem of the download option not showing up on MyEsri it was a snap for me too... after some frustration finally a phone call to customer support said "close the browser and reopen"!  i can't imagine why that worked but it did...  thanks Trina!
