I need Help with OSM Relations in Arcmap for my Bachelor Thesis
659
01-03-2021 04:32 AM
SvenKuder
Hi, do you know a way how i can get OSM Relations with all the Attributes in Arcmap.
I see all the Attributes in JOSM but i can only export them as GPX and after that i lost all the OSM Tags. Is there any way to get this Data into Arcmap?
Thank You!
Robert_LeClair
Esri Notable Contributor
I wonder if the Data Interoperability extension for ArcMap would be able to import the data in a shapefile or geodatabase feature class?  OSM is a supported read-only format in the extension.
SvenKuder
I will try this, but i can already load OSM Files with the "ArcGIS Editor for OSM 10.8.x Desktop" do you think the Data Interoperability will Load it different?
Robert_LeClair
The Data Interoperability extension will convert it from a non-Esri format to a geodatabase feature class so it's different.
