I'm trying to convert a geometric network to a trace network and get the error: Cannot create a dirty area outside the topology's spatial domain.
1375
08-26-2020 11:58 AM
ChrisJensen
What's the fix to this?
Tags (1)
George_Thompson
Esri Notable Contributor
Do you have features outside the spatial extent?
Can you provide more information on where the current geometric network is located?
It is hard to know much with out some more details, is the output a local file geodatabase or on a network share?
--- George T.
ChrisJensen
The feature dataset that contains the geometric network (sanitary sewer)was copied to a file gdb on a network share.  I had no issues when converting another one (storm water).  I have tried putting the second one into its own file gdb.but  get the same error each time I run the convert tool.
ChrisJensen
No features are outside the spatial xtent
