I'm looking for the National Land Cover Data set (NLCD) that is not an Image.
2611
6
06-03-2020 08:38 AM
VincentRobinson
I'm looking the National Land Cover Data set  (NLCD) that is not an Image service but a dynamic shape file, can someone let me know where I can find this?
JoeBorgione
What is a dynamic shape file?
VincentRobinson
A format in which I can interact with, export ,view tables and ect.
JoeBorgione
Okay, a feature service, probably a polygon feature service most likely derived from the imagery.
Katie_Clark
MVP Regular Contributor
You can also look into creating the data yourself from the raster layer with the Raster to Polygon tool.
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
VincentRobinson
Thanks I will try it.
George_Thompson
Esri Notable Contributor
Take a look here: Multi-Resolution Land Characteristics (MRLC) Consortium | Multi-Resolution Land Characteristics (MRL...  it look like you can download it there as an image then convert it.
--- George T.
