I'm having trouble with the keyboard shortcuts changing after updating to 3.4.
243
02-13-2025 09:13 PM
-_-
Ever since ArcMap, I've used the keyboard shortcut "Alt+s" to save feature changes, and it's been very useful.
However, after updating to 3.4, pressing "Alt+s" now selects the "Share" tab, making it difficult to save. (What's more, the word "Share" is surrounded by a box, and the word appears in a black box as well.)
How can I make saving take priority?
Robert_LeClair
Esri Esteemed Contributor
In ArcGIS Pro 3.x, CTRL-S is the keyboard shortcut to save a project.  In the Keyboard Shortcuts UI (see images below), you can search for and find many of the shortcuts available in ArcGIS Pro.  Furthermore, you can create your own keyboard shortcuts as described here in the help documentation as well as all the other ones available in ArcGIS Pro.
-_-
Thanks for your answer.
Yes, I know that. It's a very good feature.
I use Ctrl+s to save a project, but I also created and used Alt+s as a shortcut for the save button in the map's Edit tab.
In 3.4, for some reason Alt+s doesn't work, and I'm having trouble.
Robert_LeClair
At the top left of the Keyboard Shortcuts pane, if you click the Keystroke box and type S in the box to the right of the Keystroke word, you see all the keyboard shortcuts that use "S".  It appears that Alt+S is already being used for the Skip Step shortcut in the Global group.  I "think" you can delete this keyboard shortcut by clicking the "X" to the right of the box that contains "Alt+S"  Then you can use/create/apply the Alt+S to be used for save on the edit core tab.
