I have an aerial image rectified to the earth. Now I need to build an attribute table saved as .csv
283
04-05-2024 06:15 AM
SKautz
I am new to ArcGIS Pro and would like to understand the following:
Now I need to build an attribute table saved as .csv, fields with information for Project, Roll, Roll Suffix Flight Line, Frame,  Frame Suffix and more.
I have built a Raster Attribute Table.
In that table I get three columns OID, Value and Count for 242 rows and the other 52 columns are 0s.
Help.
Robert_LeClair
Esri Notable Contributor
So if I'm understanding correctly, you want to add 5+ new attribute fields to your existing raster attribute table?  If yes, you can do this via the Add Field (Data Managment) GP tool or the Fields Designer.
SKautz
Thank you for the reply.
This is the table now.
How do I get the values for the rest of the fields?
I really appreciate your time and help. Thanks
Robert_LeClair
You're welcome!  So if you have the attribute values to enter into the table, you can use the Calculate Field geoprocessing tool to calculate values.  Or are you looking to have the data automatically entered into the table?  What is the end goal?
