I can't seem to choose the reclassify method in the reclassify tool. It only allows me to use equal intervals not quantile or others.
697
08-17-2019 09:25 AM
IanIrmischer
I can't seem to choose the reclassify method in the reclassify tool. It only allows me to use equal intervals not quantile or others. What am I doing wrong?
KoryKramer
Esri Community Moderator
Hi Ian,
What if you go to the layer's Symbology first and choose the classification method there; then open the Reclassify tool?  I believe it will work based on the public explanation provided on this equivalency issue noted previously for ArcGIS Pro: https://support.esri.com/en/bugs/nimbus/QlVHLTAwMDExNTEwNw==
IanIrmischer
Hi Kory, Thanks for the comment. I saw that post but unfortunately that techniques does not seem to work when you use it in model builder. Any other thoughts?
KoryKramer
