I am connecting a PostgreSQL database to ArcGIS Pro and it connects but when I attempt to open the attribute table I receive a "Shape Integrity Error" and cannot view it.
5029
10
02-27-2019 02:19 PM
PaulLomas
I am able to view the attribute table without any errors when I connect the database using Arcmap.
Any idea on the issue?
Thanks in advance
FlavieMoraux
New Contributor III
Support does not recognize that (case of repeated points) as a software problem. For them the geometry is erroneous while it is valid for PostGIS. Mentioning the validity rules in the documentation would have been helpful...
Their only workaround is to correct the data upstream, they suggest ST_Simplify function with tolerance of 0.
