How to you cut a polygon with an intersecting line?
216
02-20-2023 03:32 AM
SandyShores
Greetings
I am searching for a tool which could easily allow me to cut polygons "with" lines, as I am making a map where habitats of particular animal are overlapping roads and I don't want that as I need to merge the polygons later on and I want to avoid making it a blob. Doing it manually is out of the question as there is about 300 polygons and twice as much roads.
JohannesBierer
I would buffer the roads with a very small distance or the distance you think is appropriate for the roads and then use the pairwise erase tool?
Or try this tool:
https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/feature-to-polygon.htm
JohannesLindner
MVP Regular Contributor
You can use the Split edit tool to split features with other features.
Here, I'm splitting 4 polygons by 3 polylines:
Result:
This changes the polygon feature class, be sure to backup your data!
Have a great day!
Johannes
