How to split roads using census blocks
648
07-11-2021 10:36 AM
Surya_Vaidy
Hello! I'm a college student and this is sort of my first time using GIS extensively outside of a class setting. What I'm trying to do is split roads using census blocks so that I can try and visualize two things: which side of a road falls into which census block and how many smaller roads are inside the blocks themselves. However, I have not used the split tool before and I'd like to know a little more about the tool and if it can even be used in the manner I wish to attempt. Thank you!
DanPatterson
MVP Esteemed Contributor
Split (Analysis)—ArcGIS Pro | Documentation
split also uses tiling and parallel processing should the datasets be large.  Links to the appropriate help topics are within the split help topic
... sort of retired...
JayantaPoddar
I believe a Pairwise Intersect (same as Intersect) tool will give you more desirable answer, if you want the attributes of the Census Blocks alongwith the Road Data.
Give it a try.
Think Location
DanPatterson
CanJM
New Contributor II
This method worked for me.
DanPatterson
You should Accept as Solution the thread that answered your question to close the thread as answered
