How to set a date to NULL in Field Calculator
8970
14
07-31-2018 03:04 PM
FionaRenton1
Occasional Contributor II
I'm using ArcPro 2.2.1
How do I set a date to Null instead of 1/1/1900 in the field calculator of a table in a file geodatabase?
My work around was to do this in 10.4.1 and calculate a set of records to NULL but I'd like to break the habit!
MatthewLeonard
I thought about this too, but it says "Null values allowed."
MatthewLeonard
I can't enter a valid date for the value either.  It may be that I just don't have permission to edit this field or this feature class.
JoeBorgione
Have you been able to edit this feature class/table in the past?  What version of arcgis created the file geodatabase and/or the feature class itself?  I can't remember if the sun has set on 10.3; it's gotta be close though.
DanPatterson_Retired
It' like us Joe... mature
Esri Support ArcMap 10.8
scroll down, it is near the precipice
JoeBorgione
Yeah but.... aren't you retired?  That makes you more mature than me....
