How To: Rotate geographic features in a data frame but maintain the left to right position of annotations
856
6
08-14-2019 04:11 PM
JohnPlunkett
Is there a way to do this in ArcGIS Pro?
I may have missed the setting for this in ArcGIS Pro
How To: Rotate geographic features in a data frame but maintain the left to right position of annota...
WendyHarrison
Hi John,
Presently the only way to do this would be through code - converting the geometry of the annotation to a point.
What is the workflow you're trying to achieve?  Would it be possible to do this through labeling?  We have an option on the map properties to specify whether to rotate the point and polygon labels when the map is rotated.
General label settings—ArcGIS Pro | ArcGIS Desktop
thanks,
Wendy
by Anonymous User
Not applicable
Hi John-
In ArcGIS Pro this setting exists as the Angle alignment property. You can choose to align symbols to the map instead of the display. This is a layer specific setting and not a general option applied to all layers.
JohnPlunkett
Hi Aaron
Thanks for the response - I think that Annotations are done slightly differently.
This is the settings I get for annotation symbology
KoryKramer
Esri Community Moderator
Wendy Harrison‌ Is there a way to do this in ArcGIS Pro?
WendyHarrison
I'll look into it
Wendy
WendyHarrison
Hi John,
thanks,
Wendy
JohnPlunkett
Hi Wendy the user wanted to use annotations to have more fine grain control over the label position etc..
If you have an example of the code that would be helpful
