How to remove sub-heading of <Value> from table of contents and legend?
2060
10-11-2017 08:39 AM
PatrickBoyd
Hi there,
I was just wondering whether there was a way/the best possible solution to removing the sub-heading 'Value' from the table of contents. Reason being that when I try and create a legend on layout view, there does not appear to be a way to delete this sub-heading (see images for reference). Thanks.
Tags (3)
DanPatterson_Retired
Can't you not select the legend in the layout like you could in arcmapk convert to graphics, ungroup, then delete the bits you don't want?  followed by group back etc.  Haven't used the layout much so I don't have one to experiment with
KoryKramer
Esri Community Moderator
Patrick Boyd
With the Layout in focus, select both of those raster layers (Peak Ground Velocity and Peak Ground Acceleration).  Right-click one of them > Properties.  This should open the Format Legend Item pane.  Mine is on one layer, yours should say [multiple items].
At this point, we see Value in the legend.
Uncheck Headings in the Format Legend Item pane.
Voila!
I hope this helps!
