How to remove duplicate values from Dynamic Text (Attribute Value)
4917
12
02-18-2021 04:00 PM
by Anonymous User
Not applicable
I'm trying to use as much dynamic text as I could for our maps. I wanted to get rid of duplicate Township labels and just show 1 value.
MoyaCalvert_01
Apparently fixed in ArcGIS Pro 3.2
LindsayRaabe_FPCWA
Just received this update;
"Thank you for your patience as we have investigated this issue. I just wanted to update you on this case. After extensive testing, it does appear that there is an issue with the Distinct function when used in the Table Attributes option for Dynamic Text. We were able to replicate this issue and found that a blank output was returned when applying the Distinct function as outlined in the Esri Community post that you sent through.
Because of this, we have lodged a bug on the issue BUG-000137676: Unable to remove duplicates using 'Distinct' Arcade function in Table Attribute Value Dynamic Text in ArcGIS Pro. "
Hopefully see a fix in 2.8!
Lindsay Raabe
GIS Officer
Forest Products Commission WA
LindsayRaabe_FPCWA
Just got this in an email from ESRI.
Updates have been made to the following defect which you are associated with:
BUG-000137676 - In ArcGIS Pro, unable to remove duplicates using the Distinct Arcade function in the Dynamic Text tool for table attribute values.
Status: Fixed (Learn More)
Version Fixed: 3.2
Additional Information: This issue is addressed in ArcGIS Pro 3.2.
Lindsay Raabe
GIS Officer
