How to export my map into PNG file in Python in Arcgis Pro
400
7
09-29-2020 07:10 PM
wwwu
The counterpart of that in ArcMap is arcpy.mapping.exportToPNG(),
but i could not find the substitute in Arcpy.mp in arcgis pro
Tags (1)
Reply
JoshuaBixby
MVP Esteemed Contributor
There are exportTo... methods bound to MapView—ArcGIS Pro | Documentation.  Either use the activeView property of an ArcGISProject or the defaultView property of a specific map.
aprx = arcpy.mp.ArcGISProject("CURRENT")
map = aprx.listMaps()[0]
map.defaultView.exportToPNG()
DanPatterson
MVP Frequent Contributor
From
Map—ArcGIS Pro | Documentation
A map can also be accessed from a MapFrame object using the map property. Note: arcpy.mp does not provide access to map views within the application; it only provides access to MapFrames.
perhaps
MapFrame—ArcGIS Pro | Documentation  there is export to png there
Plus other salient bits of information beginning here
Migrating from arcpy.mapping to ArcGIS Pro—ArcGIS Pro | Documentation
... sort of retired...
wwwu
Thank you for your reply!
The documentation says that:
the method of ListElements on Layout Objects can get access to MapFrame
But when the scirpt below return a null list, do you know the reason?
pro = arcpy.mp.ArcGISProject("CURRENT")
mp = pro.listLayouts()
Reply
DanPatterson
See the code samples in
Layout—ArcGIS Pro | Documentation
Of course, it will only work if you have one or more layouts
Reply
wwwu
But I don't want to export my layouts. I just want to export my map Object into a PNG file which comes from a .shp file. In the interface, I only need to click on the map icon and click on sharing, then I can export your map into a PNG file, which means map file can be directly exported into a png. But I couldn't find that function in Map class in the documentation.
Reply
JoshuaBixby
wwwu
Thank you! This is just what I need!
Reply
JoshuaBixby
Please mark a response as Correct to close out the question.
Reply
