How to export elevated contours to a dwg or dxf file
6603
01-05-2016 11:06 PM
EricSepich
import arcpy
from arcpy import env
arcpy.Contour_3d(inRaster, outContours, contourInterval, baseContour)
The above works however when I look at my contour lines in AutoCAD they contain no elevation. For some reason the command only works on the base raster layer which came from USGS if I plug in another layer (like a contoured vector layer) if fails with an error. I really need to have elevations so in AutoCAD so I can build a DTM
Tags (3)
SteveLynch
They contain a field called contour and are not Z or M aware.
-Steve
MikeCusi
You would need to use the "Add CAD Fields" tool, then populate the appropriate fields before using the "Export to CAD" tool.
KarenHodge
Export to CAD will look for a field called "Elevation" and use that for Z values if the geometry is not itself Z aware.
You can do that by
- adding a new field and calculating it from your 'Contour' field.
Or
- setting an alias on your 'Contour' field of 'Elevation'.
Here's an article that talks about this:
31687 - Retain elevation values when converting from a shapefile to CAD
