How to define projection of an .las file with an "unknown projection" that I know is actually in MGRS?
12985
14
11-02-2020 12:20 PM
ChristopherCook
I received this data from a company that collected the data. The original data were a .pcd file that I converted to an .las using CloudCompare, as I couldn't seem to find a way to get the .pcd into ArcGIS Pro.
When I added the .las file to my Table of Contents in ArcGIS Pro I realized that it has an Unknown Coordinate System. I know that this file is in MGRS, which I had heretofore never worked with (it took me a while, but I eventually realized "mgrs" is in the file name).
I am attempting to define the projection so that the .las tile is placed in its spatially correct location. However, I see no way to choose "MGRS" as a projected coordinate system when I attempt to define the projection. I have also attempted to perform this action when making an las dataset, by making a PRJ for the file, but this does not seem to help. For reference, I tried following the directions found here: ArcGIS Help 10.1 in the section called "Spatial Reference". I feel like this gets me closer to solving the issue, but I see no way to edit the PRJ file that this process creates... so I am still stuck with an .lasd file that is based off of an undefined .las file. Anyone have a way to do this or a work around for defining a projection in MGRS for lidar data? Am I way off here? I've included a snip of my window to provide some info regarding the .las I am working with.
Thank you so much for your help.
-Chris
BrianStearmer
This is correct, MGRS is not a coordinate system.  It is a reference system on top of UTM.  My guess is the data was either (1) projected into a WGS84 based UTM Zone or (2) it is truly unprojected (as a lot of military lidar systems will put out unprojected pcd files).
BruceHarold
You can convert PCD to LAS directly using the Data Interoperability extension, including conversion from MGRS to a real coordinate system using the MGRSToLatLongConverter.
ChristopherCook
Hi Bruce,
Thank you for your help. I will give your suggestions a try this morning and let you know if I have success.
Chris
ChristopherCook
Hi Bruce, I attempted to use the Data Interoperability tools to create a Reader (in Workbench... which I have never used before) to read the original PCD file I have been working with, but I received the below error. Any thoughts regarding this isssue? I then attempted to use the Data Inspector, and I got the second error below.
Thank you,
Chris
Data Interoperability (node locked-crc)
Permanent License.
Machine host name is: precisionm4700b
Operating System: Microsoft Windows 10 64-bit (Build 17134)
Copyright (c) 1994 - 2020, Safe Software Inc.
Safe Software Inc.
Creating reader for format: Point Cloud Data (PCD)
Trying to find a DYNAMIC plugin for reader named `PCD'
Module 'PCD' is unavailable for use with this FME edition
Failed to obtain any schemas from reader 'PCD' from 1 datasets. This may be due to invalid datasets or format accessibility issues due to licensing, dependencies, or module loading. See logfile for more information
FME Session Duration: 0.8 seconds. (CPU: 0.4s user, 0.3s system)
END - ProcessID: 4188, peak process memory usage: 65056 kB, current process memory usage: 65056 kB
Program Terminating
Translation FAILED.
Workspace generation failed. Parameter file was C:\Users\clcook2\AppData\Local\Temp\ArcGISProTemp5604\FME_1604440320787_6784.
_______________________________________________________________________________________________________________________________________________________-
Failed to open the dataset 'C:\Users\clcook2\Documents\ACM_Lidar_PCD_LAS\tiled_utm_20200731_-1_1-mgrs.pcd'
DATASET INFO:
DATASET: C:\Users\clcook2\Documents\ACM_Lidar_PCD_LAS\tiled_utm_20200731_-1_1-mgrs.pcd
NUMBER OF PARAMETERS: 0
BruceHarold
Chris that looks like a bug, the format is licensed.  Please log a support call, we have a couple of options.
I can process your data too if you can share it.  Email me as bharold at esri dot com.
