How to decide whether a polygon lies completely within another polygon
664
08-20-2021 10:45 AM
zhongying_gan
Hello. I'm using ArcGIS Pro 2.8.2. I have a layer of census block (polygon layer 1). And I have another layer of the center point latitude and longitude of the census blocks (point layer). I use this point layer to generate circular buffer area of one mile around the center points (polygon layer 2). Now I want to determine whether for each census block, it completely lies within its buffer area. For example, in buffer_polygon.png, the census block does not lie completely within its circular buffer area of one mile. I was wondering which tool I should use and which steps I should take to determine whether for each census block, it completely lies within its buffer area. Thank you.
JayantaPoddar
Try Select by Location.
Relationship: "Completely Within"
Think Location
JayantaPoddar
Think Location
zhongying_gan
Thank you. It worked!
