How to calculate the arc/curve of a road network?
914
03-15-2024 02:24 AM
Ugglefar
I am interested in knowing how arced/curved the roads are in a road network (polylines). The reason is that I want to infer how far a driver can see. If the road is too arced/curved the surrounding forest might block the view.
What is the easiest way to go about this?
Thank you.
MErikReedAugusta
MVP Regular Contributor
Interesting challenge.
One thing that might be interesting to check is comparing the distance from Point A to Point B along your centerline against the as-the-crow-flies distance.
Tons of false positives & negatives, but it might yield some interesting results, all the same.
If you have a polygon dataset of that forest coverage, you could also experiment with how these lines of measurement intersect or don't intersect the forest.
M Reed
"The pessimist may be right oftener than the optimist, but the optimist has more fun, and neither can stop the march of events anyhow." — Lazarus Long, in Time Enough for Love, by Robert A. Heinlein
Ugglefar
Thank you! I will try it.
