How do you create a GRID in ArcGIS Pro, with the ability to summarise features within each square of the grid?
9233
11
03-05-2019 05:51 PM
MelissaLandewee
New Contributor II
Basically, I have points on the map with $ values, as well as polygons showing areas of risk.
I want to create a 20km by 20km grid over my map, and summarise the total $ value of all points within each square, and the percentage of the square that is taken up by the risk polygons.
Can someone please advise if this is possible in ArcGIS Pro, and what tool you would use to create the grid?
Thanks!
MelissaLandewee
New Contributor II
Hey thanks so much for both of your help! It worked perfectly in Pro and the business was very happy with it, however they now want to share it more widely - Do you know if there is a way to share this to web without it being skewed considering the map on ArcGIS Online is not the same projection?
curtvprice
MVP Esteemed Contributor
