How do I update ArcGis Pro when the update installation process fails?
976
11-08-2020 01:41 AM
DaveP
Hi all,
When I log into ArcGIS Pro (version 2.6.0), I am prompted with a message saying that "a software update is available for ArcGIS Pro". When I try to download the update, it fails and I prompted with the following error message; "ArcGis Pro and ArcGIS Pro Help must be installed in the same installation context (both as per user, or both as per machine)".
I have had this problem for quite some time.
 Any guidance or advice on how to resolve this issue would be much appreciated.
Many thanks.
D.
Tags (1)
Asrujit_SenGupta
MVP Regular Contributor
I would recommend to continue the discussion in your old Post, so that all the suggestions or any findings are documented in one single Post.
https://community.esri.com/thread/259146-arcgis-pro-software-update-is-not-working
DaveP
Thank you for your suggestion.
I have tried to continue the discussion on the old post although there have not been any responses.
MDPSAdmin
New Contributor II
Hi Dave,
Any luck on this issue ?
Just came across the same issue now 😞
DaveP
Still no luck with this I'm afraid, I am still experience the same issue and cannot update the software. Are you able to provide any insights on how I can update the software?
Many thanks.
D
