In ArcScene it's very easy to use the View Settings to adjust camera position and view angle. Where is the equivalent for ArcGIS Pro? I need to position my camera to a precise location to recreate a 3D scene. I have a point where my camera should be. How do I position my viewport to be at that specific point? Thanks
There is an addin on github that allows you to set the camera position in a scene. Just rebuild the solution in Visual Studio and the addin will be added to your AGPro.
addin url: https://github.com/Esri/arcgis-pro-sdk-community-samples/tree/master/Map-Exploration/CameraNavigatio...https://github.com/Esri/arcgis-pro-sdk-community-samples/tree/master/Map-Exploration/CameraNavigatio...
installation guide: https://github.com/Esri/arcgis-pro-sdk#installing-arcgis-pro-sdk-for-net
Kind regards,
Barth
I tried this addin and it is okay. Still no way to modify camera lenses or achieve isometric views (like City Engine). Not sure if you need to replicate a certain perspective but I suggest you submit it to the wish list for future Pro updates like I did.
