How do I get rid of an outlier in an enriched group?
708
01-31-2023 09:05 AM
junocs
I have a layer of blocks in New York City that I have enriched with census data to display the percent of 16-year-olds in the population. However, there are some obvious outliers: very very large blocks with only a few people living in them, and so a large percentage of 16-year-olds even if there's only one 16-year old.
How do I get rid of these outliers, and make them the color of their surroundings?
Robert_LeClair
Esri Notable Contributor
I was able to download the *.lyrx but without the data, it doesn't help me much.  What I did do was add the USA_Block_Groups from ArcGIS Online and used the attributes from that feature layer to mimic what I think you should try.  For Graduated Colors, I'm using the field - AGE_15_19 and normalizing on POP2010.  This gives me a better % for 16 year olds compared to the block population.  See below.
Robert_LeClair
Is it possible to share a sample of the data so that I may work on it to determine a solution for you?
junocs
Thanks!
I can't seem to get the actual data out of arcgis, but I have a layer file here. The very last columns show the main data that I used.
Basically, my process was to get the USA_Block_Groups layer from Living Atlas, clip it with a random NYC boundaries map I found on arcgis online, and then enrich it with census data (focusing on the amount of 4-year-olds in the 2010 census).
Robert_LeClair
junocs
Thank you so much! I'll try that now
