Hey!
I need help how do I get the text symbol over a symbology?
I have a road that I assigned to, but I need to change the symbol and size of the icon over the road.
Here is what I am talking about
I need the oval shape change to square on that number 127.A ?
@DEAF_PROBERT_68 I typically start with the ready to use Text symbols and Label Placement options in ArcGIS Pro Labelling Ribbon. For e.g. use Shield > Road Centerline with or without North American Streets label placement.
You can modify, fine tune the look and feel as needed using labeling properties.
Reference: https://pro.arcgis.com/en/pro-app/latest/help/mapping/text/labeling-basics.htm
Thank you. That worked. I spent some time figure it out...
