How do I add Arcgis world geocoding service to Arcgis Pro?
3047
10
03-30-2020 08:58 AM
ToddOlsen
New Contributor III
I have looked at the previous entries. It shows up in my profile settings and I can manually add to each product. Put I want it to be a default in each of my new products. When I try to add the portal, the image attached is what I get:
Please help with this issue. I cannot chat or open a case to figure this out.
Todd
DonShawEsri
Hi Todd, you are trying to add a REST Service URL to your project's Enterprise Portal list. This will not work.
By default, the World Geocoding Service is listed under Locators
ToddOlsen
New Contributor III
sorry but it is not listed in the Locator file:
DonShawEsri
Are you signed into a Portal / ArcGIS Online organization that has access to the World Geocoding Service?
In your ArcGIS Online organization, is the Geocoder under Organization > Settings > Utility Services ?
DonShawEsri
Can you try this as well?
  1. Add an ArcGIS Server Connection using the following Server URL (Insert ribbon > Connections > New ArcGIS Server): http://geocode.arcgis.com/arcgis/rest/services
  2. In the Locate pane, open the Settings tab
  3. Select the "Add a Locate Provider" button and choose "Add Locator"
  4. Navigate to the Server connection and select the World geocoder.
ToddOlsen
New Contributor III
Yes I can add it to the project but I want it to always be there when I open a new project and not have to manually add it each time
Robert_LeClair
Esri Notable Contributor
Todd - once you've added the ArcGIS Server Connection, go to the Catalog Pane -> Servers, right click on the new "services on geocode.arcgis.ags" and click "Add to New Projects."  Every new AGP you create will have this Server connection added to them.
ToddOlsen
New Contributor III
I have need added the server to every new project but I still have to manually add the world locator to every new project in the locate pane. How do I solve this?
ToddOlsen
New Contributor III
my current setting...it is there
NeilCurri1
New Contributor III
Same problem here. I have 1) followed the workaround in this technical article (Problem: ArcGIS World Geocoding Service does not display in ArcGIS Pro) and 2) Verified that the ArcGIS World Geocoding Service is the service listed in the Geocoding setting of our ArcGIS organization. I still have to add the service every time I begin a new project or open an existing project to which the locator has not yet been manually added using the workaround described in the technical article above.
