How Do I add a Field to a Raster with no Table?
1554
11-29-2021 04:37 AM
EricGurney
Hello, I'm in need of guidance. Are there any links that outline the process of animated kernel density rasters?
Time based raster animations are the staple of great qualitative analysis! You see them on your phone or television (if you watch or look at a weather app) when you see the satellite or radar animation.
It equally useful in detailed raster analysis. So I -
  • Created a kernel density layer from points. (no table is produced)
  • Exported a clipped raster into a geodatabase (no table produced)
It was when I searched for "add raster attribute table" that I soon realized, either I'd better join Esri and develop such a thing, or ask my Esri friends and community for help 😉 I chose the latter.
DanPatterson
MVP Esteemed Contributor
Normally you use
Build Raster Attribute Table (Data Management)—ArcGIS Pro | Documentation
but I suspect you have a floating point raster, so....
You cannot build a raster attribute table for a raster dataset that is a pixel type of 32-bit floating point.
... sort of retired...
EricGurney
You're correct Dan. It is a pixel type of 32-bit floating point. Are you aware of any "work-arounds?"
DanPatterson
Not without converting the raster to an integer raster.  You can do a
int(raster * 10)  style conversion but you have to remember you scaled the raster up by a factor of 10.  Or export the table to excel, csv etc and scale down there.
If you do an int(raster) you will lose all decimal precision.
Other workarounds entail producing summary tables outside of pro (eg. using numpy) which may not be as easy as the other options mentioned
curtvprice
Float rasters do not support raster tables, because they would have millions of records and wouldn't be that useful. If you integerized the data you could build a raster attribute table, but I don't think that is what you want.
You want to make bunch of rasters and animate them right? I'd start here.
ArcGIS Pro Help: Animation Basics
