How can I Export 3D Scene map from ArcGIS Pro to 3D pdf?
1753
08-28-2021 11:58 PM
PeterSocha
I was wondering if I can export the scene map into 3D pdf?  I have spent more than 2 hours searching for a solution but so far no success. Is there any solution for this of 3D pdf printing is not supported?
David_Brooks
MVP Regular Contributor
The bad news is that 3d pdfs aren't supported by ESRI, but you could embed an iframe of your web scene into a PowerPoint presentation using an addin https://www.ispringsolutions.com/blog/how-to-embed-an-iframe-in-a-powerpoint-presentation
David
..Maps with no limits..
PeterSocha
Thank you for your help. I might try your solution to it.
David_Brooks
No problem @PeterSocha . If it works out for you, please mark this as a solution so others may benefit 👍
David
