How can I change my default basemap to topographic map when opening ArcGIS Pro?
940
08-21-2019 07:10 AM
AbiDhakal
Occasional Contributor III
Recently, I do not know how, but my ArcGIS Pro opens up with the Dark Gray Canvas basemap. It use to open up with topographic basemap. How can I make topographic as my default basemap when opening ArcGIS Pro?
Thank you my GIS friends.
Abi
AnninaHirschiWyss
Hi Abi,
By default, ArcGIS Pro uses the basemap set as default within your organisation (online or portal). You can change it in the Settings: Choose "Options" and then "Map and Scene".
HTH
AnninaHirschiWyss
Hi Abi,
HTH
AbiDhakal
Thank you Annina!
I do not remember changing that to a Dark Gray Canvas, but after you said I changed the Org setting for basemap back to topographic basemap.
