Recently, I do not know how, but my ArcGIS Pro opens up with the Dark Gray Canvas basemap. It use to open up with topographic basemap. How can I make topographic as my default basemap when opening ArcGIS Pro?
Thank you my GIS friends.
Abi
Hi Abi,
By default, ArcGIS Pro uses the basemap set as default within your organisation (online or portal). You can change it in the Settings: Choose "Options" and then "Map and Scene".
HTH
Hi Abi,
HTH
Thank you Annina!
I do not remember changing that to a Dark Gray Canvas, but after you said I changed the Org setting for basemap back to topographic basemap.
