Help!: How to modify the interval in the simbology?
1147
5
11-26-2017 05:10 AM
TomGilpin
Hi there, I'm not sure I know how to ask this question, I'll try: I'm trying to modify the value interval of this layer (Called "Numero") so I can specify 5 levels with the values I want (represented by size of point symbol, here 4 size categories and the values have decimals, which I do not want). I have also used the symbology to clasify the quality atributes by cathegories (called "especie", in different colors). You can see the screen shot below. Thank you!
DanPatterson_Retired
It appears that you used the default classification intervals, you can change the type of classifier and use a manual increment.  Have you looked at that option and what was the default number of classes and classifier you used?
TomGilpin
Thanks for your reply. I don't know where to change the type of classifier to manual. Could you guide me please?
Graduated symbols.. then some options there before you get to the meat of the section.
I chose 6 symbols, manual method.  Then you can go in an change the classes there as is shown in the figure.
TomGilpin
Thanks Dan for taking the time to be so detailed!. But I think I'm either not explaining myself either I'm missing something. I need categories to show different species of animals but also need to show how many individuals of each species are shown in each point data, therefore I need to show in the simbiology 6 categories(6 different colors) for species plus 5 different sizes of symbol that would correspond to 5 intervals of values (numer of individuals of each specie ). So the symbology needs to adjust for 2 atributes: Especie (quality atribute) AND numero (quantity atribute)
I think I know what you want, but for graduated symbols, I can only find normalize, and for the unique values option, you can use multiple fields, but I have never had the need for two field graduated symbols, unless it was as simple as adding a new field, calculate a new string concatenating the field values together and then doing the symbols manually.
I don't make maps enough in my workflow to have experimented with the options.
